Get the brakes checked, either badly worn, leaking slave cylinder, or bad master cylinder. If you don't have the mechanical skills or knowledge then don't run the risk, get a qualified person to investigate for you.
Thanks for that, will chase this up. Do you think the faulty brake booster recall is related to my particular issue though?There's a recall for faulty brake booster valves on the suzuki range
RECALL
get booked into a dealership, its a free repair and takes about an hour.
Nope - a faulty brake booster (or check valve) will reduce the "assistance" provided by the power brake system - the brakes will still work, they will just require more pedal pressure to stop the car.Thanks for that, will chase this up. Do you think the faulty brake booster recall is related to my particular issue though?
