1 - 20 of 22 Posts
2013 Suzuki Grand Vitara
Hi folks. I have a 2013 Grand Vitara that I use for 3 months in another country. If you go out and start the car, turn on the AC, close the door and walk away. It locks the doors!! With the keys in it and the motor running and it hasn’t moved. While driving the locks are normal
The other new developments are the radio has a message that say “System check” and I need to replace the battery in my Key FOB. I am not sure this plays in the the doors locking problem
I have checked all the fuses, there appears to be one missing or empty. By the block diagram it is “P/W T” 20 A
thoughts or ideas??
thanks
Russ P
Depending on the market, if its not detecting the fob inside it will lock approx 10 seconds after unlocking
I know the Mexican version security system locks once engines started or when driving yo prevent car jacking. This "feature " is in the owners handbook, along with a couple of other modes of operation
Replace the fob battery and see what its doing.
Reactions: Russ Partridge
thank you. I am in Central American and the FOB a battery was on my to do list for tomorrow.
If you are going to start then leave, lower the window so that you are not evicted, or keep a spare key in your pocket..
The only time any of my Suzukis will automatically lock the doors, is if they are unlocked using the fob and a door is not opened within about 20~30 seconds (I've never actually timed it).
I'd suggest you play with it a little - does it automatically relock if the engine isn't started? does it automatically relock if one of the other (not the driver's) door is opened & closed - try to define the circumstances under which it locks.
Discussion Starter · #6 ·
Yep. I am in Central America. Thanks
Discussion Starter · #7 ·
Any suggestions as to what I should run in the windshield washers. The water is very hard here
and can clog a coffee maker inside of 2 years
Pre mixed windscreen cleaner solution
If you have issues with hard water and have a dehumidifier, or A/C,, save the condensate from the dehumidifier or A/C and mix in windshield washer
Or collect rain water
You were correct, I did the drive to the store and got a 1620 3v battery and it fixed the problem. Thank you so much. Have a great day
Amazing how much trouble a fob battery can cause hehehe
Discussion Starter · #15 ·
So it is safe to assume I have the Mexican version as I am in Costa Rica. It does exactly what you are describing, I get in start the car and within a few seconds the doors lock. Can I turn this feature off??
Discussion Starter · #16 ·
PS. I did replace the FOB battery, The FOB works fine. It is the auto locking doors feature which has and will continue to lock people out
I'm not sure, read the owners manual.
what happens if you unlock it with the internal switch on the door? does it relock?
1 - 20 of 22 Posts
