1 - 11 of 11 Posts
2010 suzuki sx4 It have a j20b motor. I am replacing the accessory belt. I cannot for the life of me figure out how to get the second bolt off the tensioner?????? The one further up an towards the front. I have tried everything I know of do I really need to remove what looks like a water pump to gain access???? Can anyone point me in the direction of removing the belt tensioner?????
I've tried every possible 12mm combo including wrench is it actually a hex?
According to the manual the adjustment is done entirely at the idler hub, it doesn't appear you need to remove it.
Discussion Starter · #4 ·
The car has 150k miles belt broke due to what looks like a bad oil job the filter was not tight and loosing small amounts of oil this leaked onto belt. So I'm going to replace the tensioner. If I can get this bolt
Off.
Eye Automotive tire Wheel Wood Rim
As best as I can see these are the bolts. Not sure if it will clear the water pump pulley though.
Automotive tire Hood Motor vehicle Automotive lighting Automotive design
Discussion Starter · #6 ·
Yep that is what I'm having a issue with. I cant seem to get that out its hitting the water pump pully. I thought maybe it was possible a hex the picture is blurry enough that it looks like it. I'm going by the guys house Wednesday to look at it an put a ladder rack on his van. So I'm going to hold my phone down there and take a few pictures and figure this out or it's simply not getting a new tensioner. That the owner wants put on. But I think he will understand it's either a waterpump too or it's just a new belt and that's it.
I don't own an SX4 (but my sister does) and was just passing by this forum, but from my POV I can't see the need for a new tensioner unless there is a known fault. Judging by your photo, surely there are bigger problems to fix? If the pulley turns freely I'd just leave it.
Off.
Here's what is puzzling me - why are you trying to get this bolt off? What does it have to do with the tensioner?
Discussion Starter · #10 ·
I'd like too, being paid to replace it. I just did his chevy express van water pump plugs fluids a 180k tune up and his window motor. Everything that failed the inspection plus a tune up. An near the end of that the belt broke on his car so he asked if we could do a tune up on that an wellllllllp everything is now done except tensioner. So thought somebody out here would know.
Discussion Starter · #11 ·
Now my eyes are pretty good the top bolt does it look like a hex in that picture. Because I havent tried so little room. I have I believe a 10mm hex might be my key
1 - 11 of 11 Posts
