Good morning everyone,
To follow my last post in regards to adding accessories, it is also time as weather permits to work on a couple of issues.
The GV as presently 52500 km so almost like new but i have an issue with the keyless entry/start system and also have a front suspension noise coming from the front.
1. question on the keyless entry/start system. I changed the remote battery and reprogrammed the remote itself many times (at least i think i did....) still not able to have the doors open when i press the little rubber button on the door handle, is there a fuse of some sort that i would need to replace?
2. on the front suspension noise, the lower struts were already changed by previous owner around 35000km so i do not think it could be that issue. The noise comes when i hit a small hole and also when i turn the steering wheel left and right while driving, the gv's suspension bounces left and right and then i hear the "tunk...tunk" sound coming from i believe the right side. any ideas? i read on the forums that the bar connecting the left and right suspension could be an issue? anyone lived through this?
Thank you
Marcos
Sound political, PQ? something ready to separate!
.... Philip
