So it’s getting hot here in Idaho and the wife’s 2008 xl7 is having ac problems basically it shut off at an idle. Well more cycles the light on the dash will turn of and until it does it’s thing if you try to turn it back on it flashes at you. I checked the charge and it seems full. Thoughts is there a switch or sensor I need to replace? Thanks in advance
get it professionally checked, How did you determine charge level?
it could be pressure sensor, low or over charge, or a TEV thats sticking due to contamination, a compressor...the list goes on.
go get it checked, diagnosis is cheap compared to trying to fix it yourself or running it like it is and grenading a compressor.
