1 - 1 of 1 Posts
2008 Suzuki SX4 hatchback - TPMS relearn procedure
can anyone HELP ME ?
The original OEM TMPS units 43130-54J2
with codes 131XXXXX value stems were leaking air
I purchased 4 EZ-learn 33500 (rubber stems).
Mavis Tire programmed them (but not cloned)
but could not get them to sync with computer.
They tried their tool uploading to the ODB port which failed.
They tried the door switch procedure which SNAP ON says to use
Turn key "ON"
Press door switch 2 seconds, release 2 seconds
Press door switch 4 seconds and release (TPMS light was blinking slow twice)
With 90 seconds energize the LF, RF,RR, LR wheels using BARTECH
Turn key OFF
We tried this at least 10-15 times.
We also tried using 4+4+7 seconds which we found online
The ONLY Rochester, NY Suzuki dealer refuses to help me
unless I buy 4 of "their" TPMS sensors for $500 + $50 relearn.
I am thinking of trying the OEM replacement sensors #20087 (metal) with pre-programmed codes of 131XXXXX) to see if they may work ?
I did contact Sharader and asked for help.
Any ideas folks ?
1 - 1 of 1 Posts
