I have got my ABS, ESP and Engine management light on. It's been in for a few weeks now. I have no traction control or ABS working at all. I had it plugged in and this code came up... I googled it and it's come up with an ABS pump? Can anyone help or has anyone had a similar problem?
Sent from my iPhone using Tapatalk
Welcome to the forum.
I've just googled the code C1028 , seems quite common. Looks like a lot of people have needed the pump/module rebuilt/repaired. Doesn't seem to be a way of testing it. This is all the workshop manual has to offer..
Thanks for the reply! Does this mean there could be a risk that it may not need the pump? But there's no way of finding out until I do that if it is the abs pump or not?
Going by that..
Check for leakage.
I would assume the brakes would be spongy if there was air in the system.
I would assume the brake pedal travel would be long if there was a gap between pads and rotor (how would this happen anyway??).
Sorry I'm not much help. Couple of extra bits for the C1028.
Yeah, I'm needing new break discs very soon so hopefully that may make a difference, I'll also bleed to brakes! And you've been a lot of help, thankyou for your research! I'll see how I get on now:) just needed to check on a forum I guess before doing anything else to see if anyone else had an idea at all. Thanks for your help!
If I need a new pump I'll just get it refurbished, it's a lot to get a brand new one! And in definitely not going to Suzuki for one. Thanks for the link, I've saved this one for when it does come to it if I need a new one... And I will do!
