I have a 2008 Suzuki Forenza with roughly 70-90k miles on it and the check engine light is on; so I took it to AutoZone to get the codes read. The codes came back saying the O2 Sensor may be bad and the code is: P2A01. The tech told me it would be in the front near the passenger side, but not where exactly; he did mentioned it would be on the bottom of the car. Where would this sensor be?
The next error is dealing with the Throttle Body; the error says the Throttle Body is damaged or bent. When my wife drives the car she says driving it on flat ground, the car will OVER rev and one time at a stop light it would not accelerate. Do I just need to clean the Throttle Body out? Where is it located? Do I just follow the air filter back to the manifold? The error code is P2106.
The last error code is dealing with the Accelerator Pedal Position. (P2138) It states that APP Sensor 1 and APP Sensor 2 disagree more than 4.5% for less than 1 second.
How do I fix these issues and how can I make the check engine light go away?
