I have a 2007 sx4 manual transmission with almost 59k on it. Recently I noticed a rattle coming from under. Upon closer inspection it seems the rattle is coming from the drivetrain (about in the center). The sound starts up after about 5 minutes of driving. No performance or shifting difficulties, just this sound. Sounds like a metal card in bike spokes. Also my check engine light just came on today (haven't had that diagnosed - may be unrelated). Any thoughts?
Thanks!
I suppose this is an AWD and then I'd inspect the drive shaft U-joints. YOu have a low mileage but corrosion comes mostly with time more than mileage.
Other common issues are exhaust sytem rattle...(shields...
The CEL could be something as bad as a Catalytic Converter or as simple as a loose gas cap. Keep your gas cap rubber seal clean and lubricated and keep the cap tight (three or four clicks).
:cool:
