replaced head gasket about 1000 miles ago
daughter was driving Friday and timing belt broke (china timing belt)
installed new one yesterday and engine turns over good will try to start at beginning when I turn the key but wont
possibly crank 180 off?
also getting p2135 code
any ideas?
Starts but wont crank?
It has to crank before it can start... are you asking us to guess?
No sound = no crank
Grrrrrrrrr = crank
Vrrrm = Start/run
You have to supply correct info... do a visual on timing, then a compression test..
... Philip
your kind of a smartass aren't you
if you would read I installed new timing belt so already visually checked the timing
I was asking if I could possibly have the crankshaft 180 degrees off
well, you did visually check the timing marks......if they are correct then you work out how its out by 180 degrees.
do a compression check first.
