I have a USA 2005 Suzuki Reno, 2.0L, 16v Dtech, automatic, 155k, oil changes every 4k with air filter spark plugs oil filter. Cam Shaft Sensor was bad for acouple of years. Recently replaced cleared codes no codes showing. Vehicles started stalling or hesitating when in stop. And now will hardley start without fully depressing gas pedal.
Have scanned no codes it was all erased after cam shaft position sensor.
hi. does the car idle at all? is it ok once you start driving? it sounds like it might be your iac sensor or idle air control sensor. it controls the cars idle. looking at the engine you can find it at the back right of the throttle body. you could replace the sensor or try to clean it with a map sensor safe cleaner. just remove the sensor, spray it down, let dry and replace. just dont push down on the end of the sensor.
Thanks will try. Waiting on ignition coil going to replace it. It did idle and then when getting going it was fine. But now it wont idle at all.
