Looking for info on how to remove thr radio without wrecking the dash. I know there is a simple way to do it but I cant fiqure it out. Can anyone help me out. Thanks
I took a look in my 06 Optra 5, it sure aint like my 01 sunfire, couple screws and your were in, this is a tough one and whats nice is its already perfect size for aftermarket but how do you pull the thing out!!
Hey, just removed mine lastnight. This is pretty much getto style, but it worked nicely. Very, very carefully slide a very thin but stiff blade into the seam between the large center section and the rest of the dash. "It is held in place with simple snap tabs, no screws" Started on the left side, pried it out a little till i heard a gentle snap/pop, then went to the other side, and worked it there as well. The key is to be gentle, working it back and forth. With mine I didnt want to mess with the A/C controls, so I never actaully pried the whole cover off, maybe got it off 4 inches at the top. This is plenty. On either side of the deck are 2 philips/bolts, remove these, you can just get a screw driver in there. The radio as a L shaped bracket on either side, you need to pull the radio out a inch or two to access the 2 philips screws attaching these to the radio. once you get these off, the radio will simply slide out, through the silver bezel. I never had access to an adaptor for the harness, so I had to do the NASTY, and cut the wires. I cut them very close to the deck, but still left enough room to allow the radio to be re-installed in friends ride. There is a small wiring diagram on the top of the deck, but its a little sketchy, or I'm just daft at reading it. We re-installed the new deck, and wow!, its a JVC mp3/cd deck I got from best buy 2 years ago, now the car has amazing sound, through the stock speakers. big, BIG difference! When you hook up the new unit, the thick orange wire is actually your constant positive +"for clock memory", there are 2 yellow wires, one is a speaker wire the other is your main positive +. The speakers wires were trial an error, once you have power to the unit, its not hard to figure them out. There are also 2 black/white ground wires, I only used on and it works fine. All in all there were about 4 extra wires, I believe these were for other options available but not applicable to my unit. Hope this helps.
Double DIN DVD player mounting
Does anyone here have installed a double-DIN player in a Forenza? I own a Forenza 07 and I guess this is possible due to the size of the Suzuki default player.
But who know if this is correct?
I want to know if a special installation kit is needed. Or what do I need to do to install it.
Thank you!!
I've installed a double din in a GM before and I just had to use the factory mounts on the side of the factory stereo on the new deck and simply install. Since this car is technically a GM i figure it shouldn't be any different. I looked into a double din dvd player/7" screen, but they're a little out of my budget at the time so I install my pioneer dh-4800 until I feel like ponying up the $400 to get one of them joints.
