Hello i have 2005 jimny 1.3
When i disconnect the battery and wait ten minutes, idle of car is approximately 1300rpm.
after two days it falls to 1000 rpm. (time is variable according to usage) after 4 days idle problem starts again.
when i open lights, and fog lights or brake idle falls 200rpm sometimes engine stops.
I replaced body throttle, repaced throttle position sensor, replaced air filter, replaced spark plugs (iridium), replaced air filter, replaced pcv valve. none of these fixed the problem.
I will replace oxygen sensor.
Do you have any idea about this problem?
What market was the car made for? many 2005 Jimnys are EOBD so a cheap scan tool can be used to check live data.
I live in Turkey so I think my jimny is produced for European market. I dont know about scan tools. What does it says? Which parameters this scan tool will give me? and what is the parameter normal values that I can compare with mine?
thanks for reply
EOBD data is listed below:
A main dealer tool can access a lot more data.
