no key fob installed / drivers door working as should, can open all doors and lock / key will not work in passenger or rear door /door ajar light blinking on dash / interior light working as should / 20amp fuse sound
Assuming that the passenger and rear doors have lock cylinders that accept a key, if the key you have does not turn the lock cylinder, you'll probably need the services of a lock smith - you can if you possess the mechanical aptitude, remove the inner door panels and make sure the lock linkages are not stuck or frozen.
Can we assume you know the history of the vehicle and the locks have not been replaced at some point?
