Need help, I have a 2004 Suzuki Forenza, the radiator broke, I relace the radiator and the cooling system created to much pressure it exploded the lower hose, I fixed that and went to refill the coolant tank, and it smells like gasoline, did I blow a head gasket or crack the head, any help thanks
hi welcome to the forum. gas in the coolant is never good. its possible that you have a bad head gasket maybe bad rings. the only way to know for sure is to get it to a trusted mechanic and have it looked at. you should probably have a compression test and leak down test performed. this could point you in the direction of the problem. you should probably have the cooling system checked and make sure the thermostat and everything is working correctly and you have no blockage. any other questions just ask. let us know what happens
