Just put a new battery in and 2 days later it was dead. Jumped it off and it charged right back up. Starter, alternator and battery all show good on a auto store test. Also tested to see if there was s draw when car off, but new battery showed it was all good and there was not drain. Also, the headlights will randomly go out when driving and you have to hold the lever on and use the high beam that is the only light that then works. If you pull the emergency break when car is on and headlights are on, the light then go off when pulled. Blinkers used to work, but stopped working completely and that has been the least of our problems. Maybe someone has had the same type of problems. HELP!
