1 - 1 of 1 Posts
2004 epica,no spark.Getting codes for low crankshaft sensor low imput.System low voltage.Tried changing crank sensor ,same result .Tried another Ecu off the other epica I have that runs,Same result.grounds good.Had sticky ignition,changed that,same result.All fuses good.has fuel to fuel rail.Ready to pull out my hair.And believe it or not the other epica runs with the crank sensor disconnected.ANY HELP OUT THERE <READY TO BURN IT>:confused:
1 - 1 of 1 Posts
