hi about a month ago when i gave gas after idling it would miss a little bit, that progressed to a rough idle and stalling. i got two codes P0100, P0172, sprayed maf cleaner on the maf sensor, worked a litter better now it wont stay running and barley starts. a mechanic said i need a new idle air control sensor??? any suggestions?? thanks
IAS
Idle air speed motor,
Little thing just below the intake held on with two screws. Its an easy thing to change if that's what it is!
Can you start it by holding the gas down a bit?
How does it start and run with the MAF disconnected?
Mine seems to like to run without the MAF and idles up a bit (which tell's me the IAS is opening up) only down fall is that it will stall out if driven like that.
