Hey All,
It seems I'm having problems with my starter on my Suzuki Aerio 2003.
I can't find the starter on my car.
Does anyone have a diagram or image on where the starter is located? Can I go from the top or do I need to go in from the bottom?
I think the starter is getting stuck and needs to be replaced.
thanks!
It is a nightmare to get to if you're a novice. It is behind the engine a bit above the transfer case (if your car is AWD). It is a very hard to reach position. Unless you have small hands or just the right size tools at your disposal you'd be best to take it in.
Hey All,
thanks!
Hey did you find out if you take it off from the top or bottom
It is connected through the bellhousing... dont assume the issue is with the starter, diagnose it first
