I have a 2002 jimny auto which has a check engine light code 14.
Ive replaced the sensor checked the wiring with my multi meter. Ive got a good ground theres no breakes in the wiring from the temp sensor plug to the ecu. And ive checked that ive got 5v going to the plug and it the sensor drops the voltage to .6v when its warm. but still the ecu has error code 14 even after ive reset it.
Does anyone have another idea of whats causing this code 14?
Discussion Starter #2
Update now the check engine light is staying on and im getting code 13, 14 and 18. can anyone help me out? whats causing this check engine light. my car has a m13a engine with auto transmission if that helps
