2002 GV center console switch question
288 Views 2 Replies 3 Participants Last post by  L84sky
Vehicle Automotive lighting Motor vehicle Automotive tire Automotive mirror
This switch N A/T P
What is that used for because my 02 GV has that, and I've been wondering what it does?
And also how do you check that it still works?
Cheers
See less See more
Did you check the owner's manual?
It's for the A/T or automatic transmission, N = Normal, P = Power - essentially it changes the "shift points" of the transmission, holding the gears longer. If you want to see how it works, find a clear road, preferably with a slight upward gradient, stop the vehicle, put the switch in N and floor the throttle, then repeat with the switch in P, you should be able to see the difference.
