1 - 12 of 12 Posts
hi i have a 2002 aerio that will not engage the ac, i need a starting point for testing . locations of pressure switches and fuses and relays would be great as none of the covers are marked for identification of such. thanks
Easiest way is to go to an ac specialist and get him to put a set of gauges on it and prove it actually has a charge in it first
I am an ac specialist . I am a certified journeyman ac , I do have my gauges and read 90 psi equalized on both sides, what I really want to know is if its the relays or the clutch?
Discussion Starter · #4 ·
Without any schematics at marking of relays I am kinda blind as to what's what
Discussion Starter · #5 ·
Look I really would like to test the pressure sensor without having to them , plus the computer signals is that so hard if so I guess like always I'll just buy the stupid service manual . if it had a owners manual that identified the relays or even the fuses that be great but now you even have to buy that on line . I thought the manufacturer always had no problem supplying owners with them on line .
As am a/c specialist would you not have access to Mitchel ?
Can you not check the basics, like power to clutch (and OHM the clutch), low pressure switch..
Depending on the ambient temp, the rest pressure may be a tad high, but that is mutt..
Discussion Starter · #7 ·
I do have mitchel on demand but it is temporarily not working on my computer, I don't use it to much any more. I am an ac journey may on rooftops, walk-in, ice machines, and industrial ammonia systems ,blast freezers etc. But way back when I did cars and household stuff. I know I'm just being lazy , I was hoping that with a schematic I wouldn't need to go under the car , remove some splash panels get access to the clutch so I can identify wires to test for amperage to the clutch if the low pressure is stuck open and do I even have a fing signal from my computer to send to the pressure switches. But that seems to difficult a question to ask . I guess I will go through the tape and panel so I can see what colors them wires might be.
Discussion Starter · #9 ·
I apologise, I know everyone out there is just trying help me, but this is really frustrating. I thank you all for any advice you give.
Sincerely Trev Neufeld aka draxxlys
No need to apologize, I can see by the look on your face, you are frustrated....
Unfortunately I don't have an Aerio to crawl under, and my Mitchel has run out...
Discussion Starter · #11 ·
Well we tried, tomorrow I will fix the computer and pull it all up on Mitchell. Thanks for trying.
1 - 12 of 12 Posts
