Hey Fellas,
My Vitara had the check engine lights and I pulled the following codes.
P1410 (P1410 EVAP II Fuel Tank Pressure Control System Malfunction) and P1410 PD ...... not sure what the PD means.
I'm looking for easy things to check myself before taking it to a mechanic.
I've replaced the gas cap a few years ago with one from auto zone. The cap looks good with no cracks or damage on the seals. When I open the gas cap, I don't get any pressure buildup release sound like I do on my corolla.
Any help would be greatly appreciated, thanks.
There's a fuel tank pressure sensor on top of the tank that has likely gone bad or the wiring harness has broken...I had a very similar code referring to the same fuel tank pressure system in my 03 tracker. My wiring harness to the fuel pump and the pressure sensor had broken in two places and had to be repaired...there's no way around it, your tank will have to come down.
