just got a new daily driver 94 4dr sidekick.
want to do a 2" coil spacers, here are the questions.
I want to run 30x9.5 tires will there be any rubbing?
can I use stock wheels if not what offset wheels should I run?
A 9.5" tyre is not a recommended size for the stock 5.5" rim and therefore may not be legal where you live. A 7" rim with less backspacing would be better and would give a little more stability to offset the effects of the lift, I've run a 3" bs rim with a 9.5" tyre.
