1 - 9 of 9 Posts
I'm looking to sell my 2.2 block. here is the list...
... this is for the 2.2 I have with the 8.5:1 pistons.
• BLOCK
core .................................................. .....................$200
hot tank (per load)............................................. ........$40
de-cast (crank case, water jackets...)...........................$50
bore (.030)............................................ .....................$65
hone.............................................. ............................$25
surface block (included in bore)....................................$00
new freeze plugs installed (if needed)............................$35
---I paid .................................................. .......$415
---I'll take .................................................. ....$350
• CRANK
core (included in block core).....................................$00
crank grind (.010/.010 bearing journals)...................$80
crank polish (journals)........................................ ...$35
crank lighten........................................... ..............$180
crank knife-edge (if possible).................................$120
balance (complete bottom end)..............................$160
cryo treatment......................................... .............$250
---I paid .................................................. ...$825
---I'll take .................................................. ..$600
• OE 2.2 RODS
reconditioned big end............................................... ..$70
small end honed for floating pin...................................$75
cryo treated........................................... ....................$40
ARP pro 2000 bolts............................................. ........$95
balanced.......................................... .........................$45
---I paid over.................................................. ..$325
---I'll take .................................................. .......$200
• WISECO PISTONS FOR THIS APPLICATION
8.5:1 w/rings, pins and retainers...............................$550
balanced.......................................... .......................$30
cryo treated........................................... ...................$30
---these where bore matched to the block and balanced with the bottom end
---I'll take .................................................. .......$525
ALL OF THE ABOVE PARTS (for turbo application) TOTAL.....$1675.00 + shipping
other parts available but not required/included above for above parts...
• CLEVITE MAIN BEARINGS.........................................$ 55
• CLEVITE ROD BEARINGS.......................................... $50
• WISECO PISTONS (any compression)......................$600
• MLS HEAD GASKET............................................ ...... $95
• ARP head studs............................................. ...........$140
• ARP main studs............................................. ...........$130
• ARP hi-perf rod bolts............................................. .....$60
• ARP pro 2000.............................................. .............$95
• ARP flywheel.......................................... ...................$40
• MAIN SUPPORT........................................... ...............$95
• PHENOLIC INTAKE GASKET SET...................................$70
• HEADER FLANGE............................................ ............$70
• GASKET KIT (complete from Deawoo).........................$350
PM me, email me ([email protected]) or call 719.821.2586
Garrett
I'm bending over backwards on the price and not even so much as a comment!? :huh:
If I had the money and didn't already have an extra engine I'd buy yours and that used turbo kit (I think from nubira2.2). Or if I had the money and wanted to put anymore into the lacetti I'd be intrested in the crank
Wait wait, no...I'm not turbo'ing the lanos :huh:
Yah same with me, if I didn't already have the spare motor this is a really good deal.
Haha, it's not you, trust me! I'd really like to take it off your hands.
I'd just need to take out another loan or something in order to fund it... and I need to pay off everything I have already, which will probably take about another six months or so.
1 - 9 of 9 Posts
