I can't remove the plug in order to change my tranny fluid. It just spins in both directions. Any thing I am missing here? Thanks.
Well - if you've stripped the plug - I'd say the best place to start is by getting a replacement pan, and then drop the old pan & replace it.
Discussion Starter · #4 ·
Thanks for the responses. That is what I thought. I have never changed the fluid, so probably my mechanic just used the impact gun and slammed it in there, rather than using a torque wrench. Oh well.
Before you condemn the pan...
I had a tin pan that had a pressed in bung (came loose). If this is the case, remove pan, clean well and braze the bung to the pan.. You will then be able to remove plug...
.... Philip
