Hey guys. I currently have a 99 tracker and its been making a knocking/grinding sound in the area of the transmission/transfer case when I drive it. When I put it in either 5th gear or reverse I get a gear grinding noise when releasing the clutch. Also the 4WD doesn't work. Could this be just a transfer case issue or would I need to replace the transmission as well?
That can only be ascertained by getting dirty and down, put the car on a lift or jack stands... rotate everything by hand first, then under power...
IF the noise occurs in 5th & reverse, but not in the other gears, then it is most likely transmission related - since 4WD is also not working, you may also have issues with the transfer case or it could be front differential related.
