Im new to the forum. I've used the search button countless times to try and track down the "support arm" for the clutch pedal shaft to master cylinder ive also tried car-part.com with no luck at finding a single one. If anyone has any leads that would be greatly appreciated thank you
The first challenge is figuring out what you're calling the support arm, because, whatever it is, Suzuki does not call it a "support arm" - in addition - there is nothing, that I can see, connecting the clutch master to the pedal "shaft", which I assume to be the shaft the clutch pedal pivots on.
The clutch master bolts to the firewall and the only thing linking it to the pedal assembly is a "push rod" - p/n 23813-70C00
Lever, clutch pedal - 49820-77E71.
Thank you for the part # an the nomenclature, any ideas of where to find one? I believe ive called just about every salvage yard.... ugh
