I have a 96 trcker 4x4 5 speed I put new hubs on this summer and thought the 4x4 was working, I went to use it today and its not. The AWD light comes on and the transfer case ingages, it also ingages in 4 low but does not lock in the front tires. Is it possible the hubs are not installed properly? Or what else can I check? Thanks for the help.
Lock the hubs in if thier the manual type in 2wd .Roll the truck and see if the axles are spinning if not the hubs arent working .The hubs most likely are stuck in the out posistion in any case which is a normal occurance in a truck that never gets used in 4wd or has sat unused .
