Clean the Intake (Idle) Air control Valve..
the one under the black cover with 4 ports yeah?Clean the Intake (Idle) Air control Valve..
Thanks for the feedback and video. I’ll try it tomorrow.It doth seem that my beloved Intake air control valve is doing the same as yours is. What I did was watch a youtube clip of how to clean the wretchedly expensive creature
Cleaned it twice and then as it did the same thing yet again I took it off and oiled it against the recommendation of" do not oil". I used bicycle chain oil which is real thin stuff. It still does the bad idle but far more sporadically than before and generally only after a long downhill coast.
Thanks for the reply. The EGR seemed very responsive. I have also removed and cleaned the IAC which didnt have much if any build up. I also tested with 12v to see the actuation which is working. It seems all the external components are ok so I may need to suck it up and remove the intake manifold to clean it. Just as a test.... I turned the Idle Control screw on the Intake out about 1/2 turn. This helped by not letting the idle drop below 4-500 which helped it stabilize better but obviously this isnt a fix. Thanks for all the feedback everyone!In furtherance to the comments about the EGR valve that you serviced, you also need to confirm that the diaphragm in the EGR valve snaps back strongly once you let it go. If it’s sluggish, it can also cause your symptoms.
Just to be clear...I may need to suck it up and remove the intake manifold to clean it.
