there are two well known leak sources that can drip all over that area: 1. valve cover seal, 2. distributor o-ring.
They sell dyes that you can put into the tranny, and the leak then shows up with a black light.I do have an oil leak on my 91, so I'll check those areas (thanks!) but on this 95 I have a pretty significant transmission leak that I'm trying to locate.
I find red oil is transmission and black is engine...mostly...They sell dyes that you can put into the tranny, and the leak then shows up with a black light.
LOL. Yes, I understand that, but there are fluorescent dyes that you can put into your red tranny oil, that, when they leak out somewhere, can be seen with a black light, so you can identify where the leak is coming from.I find red oil is transmission and black is engine...mostly...
Clean everything and puff talcum powder over things, oil leaks become obvious as it cakes rather than blows into a smear.
I've used them, went back to the talc method. The dye tracks with the oil, I had a transmission that was burping out the pump to bell housing gasket intermittently, the whole underside of the thing was glowing under the black light, as was transfer case, rear driveshaft and most of the driveshaft tunnel.
I wasn't sure if it was the tc seal, or front of the pan gasket so tossed dye in it. Silly move on my part. But it did look good on the hoist hehe
Its handy stuff, but not suitable for the larger volume events. Theres not many places those things can leak. Its just finding which spot that's the key.
As much as you might need the car, don't continue driving without fitting those bolts
Not sure what you mean by correct size.... diameter of those bolts is M12, just pay attention to their fine thread! it's not the regular thread youll find in HW stores,I got a temporary bolt in place today, between the engine and trans, until I can figure out the correct size I need.
Brushes, commutator skim and undercut, and a decent clean and lube of all bushes certainly helps. If the armature is still going strong just a decent clean and new brushes is all it takes
Think about the conditions its in, and how often it gets maintained.
I honestly don't know. There's certainly a difference between auto and manual starters, but I'm not sure between the 8V and 16VOk, thanks! Do you know if the starter from a 91 8V will fit a 95 16V? I have the older starter from my 91 and could try to clean that one up to use in the 95 before actually removing the one in the 95 and having the car just sit.
It could well be the engine/trans not being firmly bolted togehter, have you put also a nut where it was missing?I noticed a hum in the car at 35+ mph, that is not present in my 91. I could even feel it in the accelerator pedal.
I could take that comment to a whole new level.......maybe its on the drivers seat holding the steering wheelIt could well be the engine/trans not being firmly bolted togehter, have you put also a nut where it was missing?
