I got trapped in a flash flood the other night, crossed a few areas of running water 1 foot deep with no trouble. When I went through the 4th area my engine suddenly quit. I got out and the water was about 2 inches below the door. I pushed the car back about 30ft to get it to higher ground. Checked the air cleaner and it was bone dry, top of engine never got wet, distributor and all was dry. The car will crank but not start. The 3 or 4 big fuses in the engine bay look fine.
Also, when it first died I pressed the hazard switch on top of the steering column. Smoke start rising from the switch so I turned it back off. I discovered that the 15A fuse for the Engine light and other dash lights is blown. It blows a new fuse as soon as the ignition is turned on. I'm not sure if this is related or is a separate problem as I've never used the hazard before.
The car has been sitting for 2 days and should be pretty dry now but still will not fire. I have not tried to replace the 15A fuse again yet, not sure if that would keep the car from starting. Where should I look next to troubleshoot this? Thanks.
