If I were to buy new rims for my tracker what would be the range of width the rim could be? I believe stock 94 rims are 15x5.5... Would a 15x7 fit? Or would it be too wide.
You'd have to determine and then calculate the rim OFF-SET in order to know if the new rim will clear inside and outside interference points (suspension, brakes, frame, fenders) and if the center hole is of the needed size too.
That and also whether you're are at stock ride height, lifted and of course the tire size (height and width), all which make a difference.
There is obviously a LOT to consider.
Center bore is 4.25" - important if you have the 4x4 hubs.
