Hello all!
FNG to this site and just bought a none running tracker and need some assistance.
Vehicle:
1993 USA Geo Tracker 4x4, 5spd manual
Appears to be a 1.6L 8V engine, fuel injected, not the original
symptoms:
-Engine cranks over
-no spark
-no fuel
-NO CEL!
Things checked so far:
-CEL bulb good, 12V @ bulb, if I ground @ the printed circuit the bulb will light but not if I ground it @ terminal A of the ALDL.
-All fuses in the fuse block have 12V on both blades
-fuse at battery good
-cleaned all 3 grounds on the firewall under the hood
-there is a module behind the glove box(don't know what it's for) that a PO cut and twisted the yellow/blue and black/yellow wires together.
-headlights and wipers do work
-installed ECU from a known running tracker and no change
-have 12v @ half a dozen wires to the ECU, couldn't make out any #s on the plugs so don't have the exact locations.
I have a snap-on MT2500 "brick" scanner but unfortunately do not have a foreign cartridge for it.
PO drove it to work and it wouldn't restart.
Messed around with it and he was not aware of anything in particular they did and it restarted, ran for a little while and quit. Sat for the last year+/- and this is how I bought it.
Thanks for any help.
Vehicle:
symptoms:
-Engine cranks over
-no spark
-no fuel
-NO CEL!
