1 - 1 of 1 Posts
1993 Geo Tracker 4wd Diesel Conversion for sale $2,500
San Diego County
Built in 2015, has very few hours since engine install. Vehicle has been sitting under cover, but was started on 5/15. Many new parts purchased during the conversion. I have kept most of the stock parts as well. It all goes with the purchase, including the original engine that was running when pulled from the vehicle. I have more photos upon request.
$2,500
• 1.9 VW AAZ Turbodiesel, mechanical fuel injection, ACME adapter kit installation
• Automatic transmission
• 105 Amp GM Alternator from ACME
• Roll bar- bolted through floor to frame
• LSI with AC and power steering
• Steel bumpers, front with provisions for winch, rear with class 3 tow hitch –Zuks Off Road
• New radiator and AC cooling fan
• New power steering pump
• Custom installation of transmission and oil coolers with fans
• Truss Skid Plate for rear axle-Rocky Road Outfitters
• Front skid plate – Low Range Off Road
• Transmission and transfer case skid plates– Low Range Off Road
• Gas tank skid plate– Low Range Off Road
• Nerf bar rock sliders -– Low Range Off Road
• Dynamat installed in floors and doors
• Engine belt driven air compressor; 8CFM at 100PSI, for tools tires, etc
• Custom gauge mounts: Trans temp, boost, water temp, oil pressure, voltage; digital tach; fuel
• Spare/stock parts-original engine
Many hours were put in to ensure a very strong vehicle that can take a lot of abuse, yet none of the new parts have been used off road.
1 - 1 of 1 Posts
