"... ignition coil fuse - <snipped> and you’ll have no dash lights."
Looking at my diagram, ignition fuse (#18, below the headlight fuses #11 & 12, left end of the block), does power lots of things. Including the coil, DRL, charging system, gauges and lots more. This could easily be the cause of a "crank but does not fire" issue. The OP would be good to double check it.
Note that Fuse 18 only has power with the ignition switch on or start.
But I don't see any connection of fuse #18 to the dash lights. The power comes from a different fuse in both fuse panels. (#13 and #3.) But I do notice that #13 is listed as powering the "Electronic Fuel Injection System", on some models. It also powers clearance lights (and dash lights), radio and lighter, along with the LOTS of other items. The OP would be good to double check it also.
This fuse #13, has power at all times.
