I just purchased a stock 1993 Tracker 4x4. Im wanting to put larger tires under it but I want to keep it stock with the suspension. What size tires could I run under? I was thinking 29's would fit but Im not too certain. Any input would be appreciated!
If you don't plan on offroading it 235/75-15 will be fine. Most tires in that size measure around 28.7" give or take a bit. If you do plan on offroading it you may rub under full flex but if you start offroading you will quickly realize that you need to at least lift it 2" anyway.
