hi can anyone help me i have a 91 samurai and the engine check light comes on it will flash once and 2 seconds later it flash twice and it does this all the time its running i think its giving me a code but i dont no what it is..i hope some one can help me thanks cidergaz
In the lower right slot of the fuse panel, there is a diagnostic slot. If a fuse is in that slot, your CEL will be in the diagnostic mode and the CEL will flash either 1-2 (normal) or any ECM errors detected. Remove that fuse.
thanks every one it woz a fuse that woz in the engine check slot in the fuse box the little thing is flashing no more thank you every one once again and hope you all have a good day
