I have a 1990 tracker with the 5 speed manual and 4x4. The other day I was idling in my tracker and it just shut off. After getting a tow I did a lot of research on here and I keep coming to dead ends.
My issues so far are as follows:
-No fuel coming from injector yet the fuel pump is ok after testing it. Fuel is getting to the throttlebody
-Noid light test gave no pulse signal.
-Tach is not moving when cranking over the engine.
-Engine will only run off starting fluid. Tach will work when the engine is running off of starter fluid.
-ECM is repeatedly flashing code 12- flipping that hidden switch does nothing.
-TPS readings are within normal limits.
-Injector is within spec
I had new capacitors put on my ECM and im still having these issues. Should I just spend the money on a new ECU?
Any help would be appreciated thanks.
