Hey folks. Can anyone give me a link or a diagram to remove and install exterior door handles please? Thanks a lot
Rob
Actually its really easy, no diagram needed.
Remove interior door panel, or if you are careful you may even be able to pull back the rear of the panel w/o complete removal but I don't know how delicate the OEM panels are so I cant recommend that. The rear of the handle assembly will be openly visible from inside. Use a common screwdriver to pop the linkage, remove the two 10mm nuts, then it can be removed.
Aluminum replacement kits aer readily available, I think I got mine from Trail Tough or Low Range.
