What is oil capacity of 1987 suzuki samurai 1.3 L engine with oil filter and which type of oil should I use. I also want to put Lucas in it and how much should I swap for oil.
Banned
I run a little larger oil filter, so the engine holds ~5 quarts. Normally, it would hold just under 5 quarts.
I run 10w40, 10w30, or 5w30 in all my zuk engines (usually one of the 30 weights though). Changing it and the filter out regularly, is just as important as running the correct weight of oil (I change both every 3K miles).
