1 - 8 of 8 Posts
Recently joined the forum.
Are there any more guys here running the Swift GTI engine?
:cool:
Samurai GTI 1.3 DOHC
Running a 1989 Swift GTI engine.
Bought the Sammy 2 yrs ago. Engine already installed but had
EFI issues. Thanks to reading this forum I found the valve cover needed
To be vented. Fixed my problems. Fun to drive.
Oohhh very pretty! nice job with the install.
I have read about the swap but never seen one. Welcome to the forum!
gti motor...
One of the difficulties with this swap is that, because the GTI is designed to install in a FWD vehicle, the Samurai firewall must be modified to fit the distributor as is pictured above. There is a right-angle mount solution but it is a bit expensive...
:mad:
Next plan to upgrade to a GM alternator.Hope the same alternator with bracket mods I have read the guys are doing the the 1.3 will work on the DOHC engine?
Are you able to snap a photo of your alternator mounting area. I've had two different GM style alts but I have the sidekick engine.
It's a worthy upgrade!
1 - 8 of 8 Posts
