Hey fellas. Got a sammi with a 1600 8 valve engine. Took it completely apart for some bodywork and now i'm reassembling. The previous owner did alot of crazy wiring that took me a while to sort out. So far i'm getting power from the ignition to the starter, it cranks but doesn't start. Checked the coil and there is no power coming out of it to the distributor and when im testing the coil i get power on both the negative and positive sides which an old mechanic tells me is normal? this where im stumped. I've been reading posts for the past hour and none seem to help me. Any input what so ever will be greatly appreciated. Thanks.
Have you got the ground wire from the distributor to the firewall?
