Did a bunch of searches but can't find any instructional or links on how to change the timing belt, does anyone have something to walk me through this?
sidekick 1.6 timing belt
Hi
I just went through this with my 95 sidekick.
A member from this forum helped out a lot ( Bex )
This site goes through the whole thing. ( The FixKick.com Repair Pages, for Sidekicks and Trackers )
I had my doubts at first but found it to be right on.
In a nut shell, bottom sprocket at 12:00
Top sprocket at 12:00 on the proper mark (there is more than one mark on the top sprocket, look for the E that reads properly when at 12:00 )
The distributer set on #4 ( sounds wrong but is right )
But go to the site there are many good tips and suggestions
One thing the keyway on the crank sprocket can be a problem when not torqued properly.
Good Luck
Jim
Engine (valve) timing is set to cylinder #4 firing. Crank key is at 12:00 - there is NO NEED to remove the center crank pulley bolt - ensure that it is torqued to 94 ft/lbs to prevent crank keyway damage. There are 2 sets of marks on the cam pulley - E (or 60A) which is what we use, and I (or 80A) which is for the DOHC engine (not us...). The cam mark is at 12:00, the cam key is at 6:00.
Then ignition timing is set to cylinder #1 firing - the car fires 1-3-4-2. The rotor is pointed to #1 wire at about 1:00 - and the rotor spins counterclockwise....
