Anyone know of a good constant 12v in the driver foot well? Been poking around with the test light but I haven't found a good one yet.
You're not looking hard enough - Suzuki almost always has a distribution fuse panel in the driver's side foot well, and if your's doesn't, you only need to look a little higher up, you should be able to locate one behind the instrument panel, under the dash, and if all ealse fails, at the steering column and the ignition switch.
Yes, as said, fuse panel left of foot well , near door pillar, and up. YOu might need sitting upside down with head in the foot well to see it and break your arm at two more locations to reach it ...but it is there...#2 on this link
www.avigex.ca/sx4/fusebox.pdf
I do not remember if part of the plastic under the dash must be taken off....but I think so
Yes...the fuse panel location is definitely not the best idea Suzuki has found....
