Hi all
I go t a SZT. There are 12v accessory sockets in the centre console and one in the boot. There is also an intriguing blanked off hole inside the centre armrest. Does anyone know if there is cabling hidden under here? I have popped out the blanking plate and tried to look round but cannot see anything obvious. Thoughts please.
Hi Rob.
The car 2019, 68 reg. It's just over a year old.
On a related subject the dashboard has a blanked hole between the air vents where a clock goes. If you pop this blanking plate the clock wiring in right there. I was wondering if there is something similar inside the armrest.
i have the SZ5, which is supposedly top trim, and there’s nothing in mine. I know the bit you’re talking about but don’t think anything sits beneath.
I guess you could run a wire from the fuse box under the carpet to the cubby. It doesn’t need to be too thick for the current - I think it’s 20amp off the front fuse or 10\15 amp off the rear fuse.
