2001 Suzuki Baleno GSR 1.8
I have a 2001 GSR with missing 5th gear and the grating noise in 1st/2nd/3rd that's likely the plate that bolt heads break on
Reading up elsewhere, apparently the internals from a 2005-2010 1.6 swift sport will swap in.
Does anyone know what other gearbox internals are compatible?
if you have a parts catalogue, i do but its in storage in another country, check if They're the same part number. thats the only advice i can offer.
strip it, find whats damaged, weld up the inevitable crack in the steel plate, grind the repair flat and refit with new screws and plenty of locktite. You will be doing bearings while you're in there.
