Hi All,
Ihave a 2000 jlx jimny with the G13bb motor and auto trans.
I would like to go to 1.6, looking at this and other forums leads me to thinking of just a BLOCK change, still using all the 1.3 top end and all the ecu system.
It appears that the head is interchangable ??
Is this possible??
What about the bell housing match ??
To fit up to the torque converter ??
Timing belt ??
What other snags ??
Regards Bill
To mate the 1.6 to the bellhousing you can use an adapter designed for a Sammy. You will need to use the Jimny flywheel and torque converter, I would expect that you would be able to use the 1.6 timing belt, the 1.3 belt will be too short. You need to modify one engine mount, I forget which one. You need to use the 1.6 injectors.
SimonDoc on http://www.difflock.doc has done the swap with a manual gearbox, try posting there or on www.jimny.se - a site made for Suzuki Jimny and it's owners only for further advice.
