went off roading today and everytime i depressed the clutch down the revs keep on dropping to a point where it stalls so everytime i approach a junction and only use the brake and clutch to slow down the engine stalls evertime. does anyone know how i can cure this? i spoke to someone today and they reckon its the engine flooding itself.
thanks
sounds to me like you have a vacume leak around inlet manifold or one of the vacume hoses has come off or split check hose ends havent gone hard and split hope this helps.
Low speed jet could be clogged, also the check valve could be leaking. Check all your hoses first, and check for manifold leaks next if you do not have any of those, then clean the carb out, blow out all recesses with compressed air.
hi i have the same problem :( its horrible!!! you cant stop its impossible!!!!!! you have to stop with the choke out on my G reg??? if you find out the problem could you let me know please!
