im looking to install keyless entry in my 07 reno. am i going to need to install actuators or are they already installed?
In my Base model '06 the dealer basically lied to me (i had no way of finding out) and said that actuators are installed in every door, in which its not the case. Since you need the key to open the door anyway, suzuki decided to put actuators into every door except the drivers side door, so you will need one.
Alot of the diagrams i used to install it (Astra 4000something) mention tapping into the seperate lock modules, but you won't really need to after installing the actuator, since it'll trick the car into thinking someone with a key did it, and lock the other doors. Just an FYI.
thanks. but just 1 more question. did you have to get the actuator from the dealer or can you get one somewhere else?
you can buy actuators online for instance ebay sells them..you can also get them at circuit city or best buy. the DEI 524N model is best to use..I have installed many of them
